Electric windows stutter
NollingtonHards
Post by NollingtonHards »
Last night i discovered that my windows will go down fine but as i press the button to raise them they stutter 2cm ish up and stop. You have to continually push and release to close the windows. Any one had a similar problem?
I have done a search on the forum but sadly nothing similar.
NollingtonHards
Re: Electric windows stutter
Problem solved, took it to pieces and blew and its all cleaned and it works properly
plod
Post by plod »
Usually just a case of resetting them
I've put a new window regulator in my dads laguna II this afternoon
Once done it went up an inch at a time
Reset it by holding the up bottom for approx two seconds and job done
1999 D8.5 HDi GLX - Sold :(
i noticed when i take the battery out of my car the drivers window auto function goes away it only goes down in intervals and you have to keep pressing it to go down and back up, but after the first go, or if its left for a while after the battery reconnected the window is fine
Aye, you need to take the window to the top and hold the button down for a couple of seconds. Might need to do it for the bottom as well depending on the car make.
swiss
Post by swiss »
It's all in yer Haynes Manuel, people ^^
The man with no car
Archangel
Post by Archangel »
yeah , had this after disconnecting battery while trying to fix cig lighter socket; but it ok now ,seems to have reset itself
Replacement !
