Help please
Help please
I have a 406 hdi 110 (2001)
I don’t know a great deal about cars, just enough to muddle by, had to have a new clutch fitted £500 because it has a MDF, any way I seem to have lost low rev’s power, plus the engine management warning light keeps coming on, also get an antipollution fault warning, so having a quick look round I noticed on the hose from the turbo to the intercooler, theirs another small hose leading to a switch of some kind, and this seems to have snapped off the hose, you can see where it should connect to the hose, can someone tell me what this switch is so I can get a new one, and could it be causing the fault, sorry to be long winded
Bob
Bob
Re: Help please
Are you saying you just had the clutch done? I'm thinking that's not your problem...
Btw where's this sensor go?
Re: Help please
hi steve
I thought it had nothing to do with the clutch, unless it had been knocked and broke
just been out to have a look again, it is on a small hose coming from the top of the intercooler,
keep trying to add a photo for you but it keeps timing out
Re: Help please
if thats broken then no doubt ull be having a boost problem as this is the intercooler boost sensor 100% thats ur problem go to a scrappy and ull get one
Re: Help please
Thanks modified406
intercooler boost sensor, i'll get one tomorrow,
Thanks for all your help
Re: Help please
wee tip when takin it off make sure u get the original clip off carefully as possible as the wee lug bit is fragile
Re: Help please
thanks for the tip,
done a temp repair, with a tube of super glue, to glue the little plastic pipe on, then put a small amount of araldite rapid, around the break to seal it, seems to be working at the moment, lol
Re: Help please
Glad to hear you've got it sorted, at least for now
I think the bit you need is no. 18
Reference Description Quantity Price - VAT Price + VAT Total + VAT Selection
0000195769 MEASURE PIPE 2.16 GBP 2.54 GBP 2.54 GBP
Reason: Can't link to a pic that's password protected :P
Re: Help please
the bit he needs is 16 as the small lobe comin from the sensor is broken 18 is just the boost pipe frm the intercooler to the sensor
Re: Help please
ull mayb get away with tht as it doesent move just make sure its in place and ull b finebob58 wrote:thanks for the tip,
Re: Help please
I think 16 is the sensor.modified406 wrote:the bit he needs is 16 as the small lobe comin from the sensor is broken 18 is just the boost pipe frm the intercooler to the sensor
Re: Help please
yes 16 is the sensor but theres a small plastic pipe comin from the sensor that attaches to the rubber pipe the wee plastic pipe has broken off
Re: Help please
Ah, with you now. Sounds like hope the araldite holds until one acn be liberated from the scrappy.....
I'll check the MAP sensor price tonight, anyway.
Re: Help please
Not cheap - two versions listed, w/out EOBD diagnostics £45.27, £57.48 with
scrappy it is then?
