Citroen ZX Suspension
I was wondering after driving behind a zx the other day how does the back wheels steer in tandem with the front ones, i have read that they do but it didnt look too dramatic in action, is there a connector to the back wheels steering them. I nearly bought a zx from an aunt who owned a dturbo one which was a rocket, the 306 dturbo just didnt compare except for styling but i quite liked the pointier design of the zx
HimBigChief
Re: Citroen ZX Suspension
Post by HimBigChief »
They run torsion bar rear suspension, and they are not meant to steer along with the front wheels. Any rear end steering on one is not meant to be there!
Image Image
I just looked it up on Citroen's Service Box 'cos I'd never heard of it - that's almost the same set-up as a Renault 4 :shock: There's still loads of them here and when they do that it means the suspension mountings have rusted away to nothing...
HimBigChief
Either as Steve says or there is excessive movement on the trailing arm bearings. Either way, it would need fixing pretty sharpish before it swapped ends round a corner.
Image Image
Some fwd designs of the 70's/80's had rear suspension geometry which altered the castor angle, (or summat like that), as the suspension compressed or extended, thus 'steering' the rear wheels a little as the car leans.
Designed to overcome the feckin useless, (sorry), advantages of fwd. :roll:
its on wikipedia it refers to some unusual suspension, and i remember jezza doing a review on the zx it was back in the 90s but he did praise its handling
Here it is
QwsedA1vEg0
The hair is different, he speaks slowly and there is no POWER but its still jezza
jasper5
Post by jasper5 »
They used to break rear top suspension mounting rubbers very often, a right pain, easy to replace though with the right tools.
Bailes1992
Post by Bailes1992 »
Just a peugeot 306, just uglier!
Passive rear wheel steering.
I thank yaw.
Bailes1992
The 406 has passive steering too!
Bailes1992 wrote:The 406 has passive steering too!
Yes, your 406 has it..........only each wheel isn't really sure which way to point :arrow: :arrowd: :arrowl: :arrowu: :lol:
the zx isnt really an uglier 306 its not too bad looking, its just more dated than the 306 i always thought the citroen was a bit quicker than the 306
Close, but it may be even tinier. :supafrisk:
