double relay at ecu
billy406hdi90
double relay at ecu
Post by billy406hdi90 »
hi guys could the double relay cause the car to keep cutting out?changed the lift pump and put a live feed 2 it in case it was wireing.any help appreciatedg
Re: double relay at ecu
If you've already put a permanent feed to the pump and that doesn't stop it cutting out, you've eliminated the relay.
Try checking whether or not you've got fuel at the filter when it cuts out.
