front fog light removal
how the hell do i remove the front fog lights out of my d9 bumper? one is steamed up and i want to dry it out.
Current car - Ph3 1.8 306
Re: front fog light removal
Alternatively I believe it's a couple of screws accessible from inside the bumper
Makes access a lot easier if you take the front wheel off and jack it up as high as you can. Not perhaps in that order though....
2003 HDI 110 Rapier Estate
1999 306 1.8 petrol.
There's an access panel (held on with torqs) I think - as the bumper returns underneath and before the wheel arch. You can see the washer bottle up there too.
Not sure if this will get you full access but it's only a couple of mins to check - I remember having a look on mine.
I think i remember reading in they HBOL that the light itself is fixed on with three 10mm nuts
1997 2.1 TD Exec (Sold)
1997 3.0 V6 Coupe S (Sold)
2001 406 HDi 110 GTX (Sold)
2002 406 Coupe HDi SE (RIP)
2001 406 Coupe 3.0 V6 SE
2003 406 2.2 HDi SE
2003 406 2.2 HDi SE
i noticed the same problem, and solved it by leaving the fogs on for a while the heat must do something. But its ironic however that the fog lights have fogged up, it would be like a fire engine catching fire, and then the breakdown recovery veichle suffering mechanical problems on the way.
i'll try this i think first. thanks406executiveHDI wrote: solved it by leaving the fogs on for a while
Or a high-ranking police officer being arrested.406executiveHDI wrote:it would be like a fire engine catching fire
No, wait, hold on...
Found the screws underneath but can't see how it comes out. It seems to be located on something above the light. Any suggestions?
theres a bastid of a screw up at the top the same as the bottom ones i dont have a clue at all of how to get it out, would need the wheel liner and front wheel off.
