i ask because on GSF they only list a fan motor for a 2.0 16v
936PC0051 RADIATOR FAN MOTOR 406 2.0 16V 58.50
Will a radiator fan motor for a 2.0 16v work for an sri?
Re: Will a radiator fan motor for a 2.0 16v work for an sri?
Errr, what's an SRi? I thought it was just a trim level. Hold on... ah, it's a turbo.
Argh, too many variables, yours should be 2x 250 watt, the 2.0s (both of them) have fans all over the place, 1 or 2, made by Gates or ECIA, with different surrounds to suit. Plus there'll be even more in the D9
The bottom line is it's anyone's guess, did you try asking them?
ive had the front off to have a look before, the 2.0 16v motor is the only one i can see on GSF tho
, would rather get a new one than trawl through scrappies.
- Site Admin & Mad Biker!
I'm sure it's the same, it's only the cowl that varies depending on if you have aircon or not.
