i have a 1999 peugeot 406 sx but it has no MFD is it easy to install one?
can anyone tell me how to install on?
thanks
MFD install
- mjb
- Site Admin
Re: MFD install
I'm presuming it's a D8?
Pop your tray out and see if there's a wiring connector first.
Re: MFD install
how can i tell if mine is a D8?
thanks
thanks
- mjb
- Site Admin
Re: MFD install
if your rear windscreen demister button is on the same row as the hazard warning switch
Re: MFD install
yeah it is in the same row
so should the wiring be there for a MFD?
- Site Admin & Mad Biker!
Re: MFD install
I hink they all have the single plug there for the mfd but if you want trip functions you will need to add another.
There will be a cubby hole above the climate controls; pull this out and you should see the connector.
- mjb
- Site Admin
Re: MFD install
If there's not even a temperature display, it'll be manual heating not climate controlteamster1975 wrote:There will be a cubby hole above the climate controls
Re: MFD install
I could be pedantic and say that altering the cars temperature changes the climate withinmjb wrote:If there's not even a temperature display, it'll be manual heating not climate controlteamster1975 wrote:There will be a cubby hole above the climate controls
Well that's my excuse and I'm sticking to it!!!
