removing plastic
bikeman
removing plastic
Post by bikeman »
Hi need some help removing some plastic.
1. How to remove splash guide above pollen filter - viewtopic.php?f=10&t=3870 didn't help
2. How to remove plastic air inlet above throttle body.
Before I break them. Thanks
Re: removing plastic
bikeman wrote:Hi need some help removing some plastic.
Look at the second to last picture in the above howto. Near Welly's fingers is a clip you can see with a bit of his red bodywork poking through. There's 2 (or 3?) of these which need to be unclipped. Then the panel can be pulled out. They're a pain in the backside though...
You'll have to say which engine you have...
bikeman
Post by bikeman »
I have a 406 2.0 petrol 1999 mk2 - I've now got a haynes manual and it unnecessarily says the wipers need to be repositioned before the splash guird can be removed which is wrong. I have done it now.
I've also got the throttle inlet off. It was help be a large screwclip which was somewhat inaccessible so I coulnd see it.
ps I tried to upload a photo but the boards attachment quota has been reached.
