Which haynes manual for sri turbo?
the one that is n reg to t reg says does not cover 2.0 turbo, so is this manual no good?
Re: Which haynes manual for sri turbo?
i wanted it to see how to change the cooling fan motor but as they dont cover the sri it wont show me will it?
It will point you in the right direction. The cooling fan setup is virtually identical across the model range. You've just got an intercooler in the way (similar to on the 2.1TD)
so its still good to get the manual?
It can be useful, yes. It still covers pretty much everything else on the car, like gearbox, driveshafts, clutch, brakes, electricals, body, wheel hubs, steering and so on...
