Hello all, I have a problem with EW10J4 engine.
I used Total 9000 engine oil for many years. At 78.000 km, timing belt changed and this problem was started to occur from this replacement.
Now, my D9 is around 90.000 km, and I need to add 1 lt. oil for every 3.000 km. !
My oil indicator has 6 points when I renewed oil, and it decreases to 2 points after 3.000 km.
Checked ground and engine surface for a possible oil leak, no there is any leak. Checked exhauts fume and there is no blueish smokes. Changed oil type to Total 7000 and it still decreases engine oil.
Do you experienced same problem ? Any help will be appreciated.
Thank you.
Selcuk
Istanbul - Turkey
[D9] Engine oil decreases regularly-after timing belt renew
I have a 2L D9 coupe and she doesn't use a drop... ever but a few years ago I owned a 1.8 early saloon that used oil at a rate of knots
It would drink a litre every month or 2k miles, I never found out where or how it was disposing of the oil but I sold the car to my dad three years ago and he has just moved it on again with 130k on the clock, still drinking oil and still going strong.
I would keep an eye on your coolant and drive.
Dan
Dan
- Captain Jack
Sometimes an engines breathng system can be at fault like the PCV valve, on lift off oil mist/oil get pushed up or sucked into the inlet manifold and burnt off. Not always easy to spot as it will only do it after lift off and will be a light blue smoke but won't smoke on acceleration (when you'd be looking out for it).
My Honda VTEC had breathing problems after I used Fully Synthetic Oil, I think the oil removed some deposits and blocked or affected the breathing, I would get blue smoke after lift offs and also found clean oil before the throttle body where it had been push/sucked up from the Cam cover breather tube.
The engine would use oil but wasn't strictly 'burning' it.
