hello steve (for knowledge basement), heres the pics of my gremlin, this is located under the drivers side rear light in the rear quater.
tiger seal is what i used this stuff is fantastic and it can even be painted if its an area that can be seen , this is the first cote , will apply another coat once that has dried.
cost £8.80 for the tigerseal and i would advise strongly to buy this before silicone sealant as i did it with silicone first and with the coldness of the metal body the silicone doesnt stick for very long and started letting water in after only 3 days. so pay for the best and get tigerseal
the black in this pic is the new seal , i removed all the old it had gone hard and was leaking water in, the big hole on the quater is were the vent goes, i will put it back in place once the tiger seal has set
and this one you can just see were it runs under the light across into the corner , , ,
