Front Head Light Wires
i need to know which wire is for the indicators on each side ?
does any1 know which colour wire it is, from what i can work out the headlight has only 1 plug on it with all wires on that
i need to connect my alarm wires to the indicators but i have no idea which wire it is :?
Re: Front Head Light Wires
i think theres a black plug that goes into the headlight, a track then goes to the indicator, but its not that hard to take out the light and check its all one unit anyway.
i can get the plug off why the light is in, wondered if any1 knew which wire is which
i'll go to the side repeaters or probably the fuse box
side repeaters are an easier one to get at.
how do you get a wire to the back of it ?
is it a wheel arch lining off job ??
it is a wheel arch lining job which if thats too much for you then use the rear lights indicators.
