MFD ??
MFD ??
today i removed the panel were the heated rear windscreen button is and hazard lights ..
behind it i found a long plug with wires on it,
is this for the MFD ? will it work if i plug 1 in ??
Re: MFD ??
Yep that's the one for the MFD. It won't do much on the diesel engines unfortunately as there's no live fuel data to tap into.
marty1979
Re: MFD ??
Post by marty1979 »
Hmmm, that's interesting. I wonder if it would work on the 2.1td, I've never seen one with an MFD but seeing as it is a very ECU controlled engine you would think that there would be some live fuel data going on somewhere.........................right?
Re: MFD ??
It's only the Bosch MP5.1.1 and the V6 ECU that provide the data as far as I know.
Re: MFD ??
Is there much available on the d8 mfd, was satnav ever an option on its mfd. What sort of display is it? Is it just a collection of 7 segment digits, or is there any dot matrix bits to it?
neildavies
Re: MFD ??
Post by neildavies »
On my D8 2.1TD, it was just for the radio (means you'd need a different radio too)
2007 307cc Sport 2.0 HDi 136
