Is the a restarting procedure after connecting the battery?
no2lurch
Post by no2lurch »
Quick quation...
After connecting the battery according to the set procedure of putting the headlights on through the open window, is there a set procedure to go through to 're teach' the ecu?
Current car - Ph3 1.8 306
Re: Is the a restarting procedure after connecting the batte
connect the battery and fire it up, cant see that being a problem
I'm sure someone mentioned a way of driving it, no idea where to look though. Might not even be this forum...
jamjar1383
Post by jamjar1383 »
is it cured now???
d9 hdi 90 rapier estate
i just plonk the battery back in, never has give me any trouble with this technique.
It sounds like he's referring to the BSI reset procedure
its an awful process, why not have a reset button instead.
I know...
so i pull the keyring for the reset, send me one of them please.
xover
Post by xover »
for BMW motorcycle before you turn on engine, you should open GAS slowly 2 times.
In such a way the ECY can learn the value of the trottle positioning sensor (TPS)
My 406 2.2 HDI has similar sensor, it might be reasonable to push gas before engine start - to have ECU learning min and max value og TPS. Obviously everyting depends on ECU model..
cheers
