Hi all,
My 2003 hdi 90 has got the shakes!
When cold at idle it is slighty shaky but when driving in 4th/5th gear at around 1500 rpm with light pressure on the throttle i.e just keeping at a steady speed, it really does shake the whole car. This stops when you apply more pressure to the throttle or come off completly.
Does this sound like the mounts have gone or something else? My garage tld me to try some injector stuff but to me it seems more than that.
Any help appreciated
Mat
engine shake
Re: engine shake
1500 revs in top gear give it some boot man!!!
ah you trying to get 100 mpg?
Re: engine shake
does the engine sound like its running ok ??
if it is running fine then it sounds like mount
probably the bottom one
Re: engine shake
omega wrote:1500 revs in top gear give it some boot man!!!
ah you trying to get 100 mpg?![]()
Re: engine shake
Open the bonnet and press the throttle and see how much the engine moves to assess engine mounts
1999 D8.5 HDi GLX - Sold
Bring back my 406
Re: engine shake
Engine sounds fine, how much would I expect to pay for the mount replacing?
Mat
Mat
Re: engine shake
mountin brackets range from £20 to £55 depending on which one it is
thems dealer prices
thems dealer prices
- rwb
Re: engine shake
I have exactly that "feature".
Used to be OK down to about 1300.
Engine mounts are fine.
I think that's just the way it is.
