As per the title I'm after 3 studs and clips that hold on hdi engine cover, I know they are quite cheap from m/d but thought someone may have some laying around cheap??
Also after 2 wheel trims, not sure on name but they are 15" and look like "speedline 205 Gti wheels" ! Can supply pic if some one has some!
Wanted, HDI engine cover clips and studs, 2 wheel trim
406 '01 110 GTX estate in white, the new tow car.
Re: Wanted, HDI engine cover clips and studs, 2 wheel trim
Err, you're not likely to find stuff like that here I'm afraid. If anyone had some spare clips then they would keep them as spare.
Same for the wheel trims, although most 406's have alloys really.
Best to go buy some really fella.
That sort of stuff appears on ebay quite a bit. The engine cover rubbers are a pile of old toss, you're best of replacing them with Renault mounting rubbers - viewtopic.php?f=1&t=10133&start=0&hilit=renault+mounts
i have a full set on sale on ebay, cheaper than main dealer.
