2.2 petrol sri spark plugs
no2lurch
Post by no2lurch »
i may be missing something totaly obvious, but where the heck are my spark plugs?
i took the engine cover off today to clean up the split oil i dropped today and thought i might get the plugs out at the weekend and see how they look. only i cant find them.
i'm being very obtuse i know!
Current car - Ph3 1.8 306
Re: 2.2 petrol sri spark plugs
no2lurch wrote:i may be missing something totaly obvious, but where the heck are my spark plugs?
There hidden by the coil packs, :arrowu:
no2lurch
Post by no2lurch »
The what where?
no2lurch wrote:The what where?
when you took the top cover off did you not notice the coilpacks?
shouid be five of em iirc or am i thinkin of a differnt type of engine :?
DiscoPol
Shiny New C5 2.2 Bi-turbo!
Post by DiscoPol »
They are or they're ..... please................
hi mate
im not 100% on this but id asume the spark plugs wouid be under the coilpacks,
as yours is over a 2.0 id presume its a 5 cyl jobbie so shouid be 5 coil packs in total, (icouid be wrong tho )
when you took the top cover off did you not notice any square ish lookin things on top of the rocker cover ?
normaly coil packs are held in place with a 8 or 10mm bolt undue this unplug and lift out the coil pack then you can get access to the "spark plug"
can anyone else confirm this :roll:
no2lurch
Post by no2lurch »
5 cylinder? I know nothing about my car!
coil packs :arrowd:
see ebay linky look at photo
http://cgi.ebay.co.uk/PEUGEOT-307-406-4 ... 4150799c12
see anything like that on your car ?
The 2.2 litre petrol engine (EW12 J4) is a 4-cylinder engine, it just has a larger cylinder size than the 2.0 litre.
As for coil packs, I've no idea about them either. I've never taken the cover off my engine myself, or changed the spark plugs myself. It's not something I feel comfortable doing, so it gets done at the garage, along with the filter changes and oil changes (though I have swapped my air filter myself).
tti900
Post by tti900 »
If you take off the plastic
engine cover you'll find the coil pack between the camshaft covers. It has what look like wax squares on the top and runs the whole length of the engine, should make sense when you see it! Its held on by eight mm bolts, undo these and the multi plug at the right hand end and it will pull off upwards.
