no air from blower vents
guttley
Post by guttley »
Hi all, any help at all will be appreshiated
Ive just got a 98 1.9tdi 406 estate with digital heating but can hardly get any air out of the vents, i can hear the fan spinning and hear the motor turning to change the vent position, ive also checked the pollen filter and its still the same with it out.
Many thanks
Glynn
gumby6371
Re: no air from blower vents
Post by gumby6371 »
So you are getting some air through the vents? That eliminates the standard ignition wire fault as it wouldn't work at all, could be a stuck pot in the control unit.
If you're lucky you might find a replacement unit from a scrapper to test. If you're struggling I have my old one which works but has a crack in it and the manual fan button cover is missing but will be plenty good enough to test.
gumby6371
Post by gumby6371 »
Sorry mate, where are my manners I forgot to say welcome aboard :cheesy:
is there any air coming through the floor vents ?
Indeed, is there air coming from anywhere at all?
gumby6371
Post by gumby6371 »
i assume from Glyn's post there is some air coming through and the fact that he can hear the vents opening and closing and the fan working suggests to me it's stuck on the lowest setting. That's why i suggested swapping the controller, alternatively push some power through the fan with a battery and check it spins?
I have the same unit in my car and if left in auto it very rarely ramps up the fan speed even on the coldest mornings, I have to manually crank the blowers up to full in the morning to clear the screen.
Come to think of it I don't ever remember actually hearing the vents opening and closing, but then again the fan is normally running at the time !
maybe the motor that controlls the vent position is stuck ?
gumby6371 wrote:Come to think of it I don't ever remember actually hearing the vents opening and closing, but then again the fan is normally running at the time !
If you wind the fan up full and then change the direction you can definitely hear the change as the flap moves.
guttley
Post by guttley »
Hi sorry for the delay and thanks for all the replies, i managed to try a different controller but still the same
the temp changes from warm to cold and back again, i can change the different vent positions, change the fan speed but still hardly any air comes out
think next step is to take it all out n have a look
so does the fan go on full speed .
i think the direction function is stuck 8)
craigtd
Post by craigtd »
check that the fan is still attached to the motor :wink:
So it all seems to work, just no air comes out of anywhere? Is the pollen filter blocked?
guttley
Post by guttley »
yes i can change the fan speed and you can hear it change, just get very little air out the vents, i tried it with the pollen filter out it made no difference at all
Everything seems as it should
So I guess either the matrix is blocked up with crud or one of the pipes that feed the dash vents is off. Weird.
have you had glovebox out yet ?
under there you can see the pipes that feed the vents.
i rekan ones come off.
