what size caliper bolts are on the rear of an sri?
jason1987
Post by jason1987 »
i need to change my rear discs and pads tomorrow, what socket do i need to undo the bolts? and are they covered by a rubber cap? as i couldnt find the bolts last time i looked
jamjar1383
Re: what size caliper bolts are on the rear of an sri?
Post by jamjar1383 »
jason1987 wrote:i need to change my rear discs and pads tomorrow, what socket do i need to undo the bolts? and are they covered by a rubber cap? as i couldnt find the bolts last time i looked
im quite sure there allen key's or torx
d9 hdi 90 rapier estate
jason1987
Post by jason1987 »
would they undo with an allen key or do i need a socket kit?
jamjar1383
jason1987 wrote:would they undo with an allen key or do i need a socket kit?
doubt ud shift it with a allen key, u'd need a socket with a allen bit, can be bought from halfords on there own.
jason1987
Post by jason1987 »
guess the bolts are covered by rubber cups and covered in dirt, thats why i couldnt find them
anyone know what size allen keY?
jason1987
Post by jason1987 »
i can only find "hex bits" on halfords not allen bits, are they the same fit?
jasper5
Post by jasper5 »
Not done an SRi before, but most caliper bolts with an allen key are 7mm.
The only other size I know of is VW Polo fronts (old models) which are 6mm.
jason1987
Post by jason1987 »
this should include the right bit i need shouldnt it?
http://www.halfords.com/webapp/wcs/stor ... yId_165572
jason1987
Post by jason1987 »
jasper5 wrote:Not done an SRi before, but most caliper bolts with an allen key are 7mm.
i may aswell just buy the halfords 7mm caliper tool then?
jasper5
Post by jasper5 »
You could if there is plenty of room to get the tool in place.
kevtherev
Post by kevtherev »
did the front discs on mine and they were torx (T55) and thread locked in too, so i doubt ya would shift them with just a normal allen key
51 plate hdi 110
jasper5
Post by jasper5 »
kevtherev wrote:did the front discs on mine and they were torx (T55) and thread locked in too, so i doubt ya would shift them with just a normal allen key
Rears Kev..... :shock: :cheesy:
jason1987
Post by jason1987 »
so fronts are hex and rear are 7mm allen? ill check with my allen key set to check what size it is before i buy any tools
jasper5
Post by jasper5 »
Fronts will be 55 torx as Kev said, but rears are 7mm, at least they are on most cars, check first like you said.
jamjar1383
i think the fronts are allen too but everyone seems to use torx as a torx bit is less lightly to slip and round off the bolt.
