Plan is to fit replacement for the snapped cam belt on my dad's 2.1 td 406.
Does anyone have diags of cambelt routing over pulleys/tensioner etc. Is it same as 1.9 diag in Haynes manual?
Anyone have diag of cambelt layout for 2.1 td
- 1.6 8v
- Site Admin & Mad Biker!
Re: Anyone have diag of cambelt layout for 2.1 td
- 1.6 8v
Thanks for the diag. When I got the Gates replacement kit it also had a diagram inside, with the very brief instructions which didn't even touch on how to remove the tensioner!
Actually, when you look at the cogs and pulleys it becomes fairly evident how the belt runs, but it's good to have a diag to confirm.
Anyhow, belt on and engine running. As belt snap hasn't appeared to damage any valves it's water pump and new auxiliary belt next!
Thks. Again.
Thks. Again.
Excellent it hasn't damaged anything, fingers crossed she fires up first time!
If you need the layout for the fan belt let me know & I'll post up the pic.
