Strange one here guys
All lights work fine on my 2001 HDI 110 Estate, brake lights, hazards, indicators, front lights, front fogs, main beam etc......But!! My rear fogs are not working.....any ideas??
Rear fogs not working?
Re: Rear fogs not working?
Hiya mate,
it couid be anumber of things,
:faulty switch,
:fuse.
:bad connection on the cluster bad earth etc,
Hopefully someone will post up some better ideas,
:faulty switch,
:fuse.
Check fuse - should be F19, passenger fusebox on your car, but they do vary.
The standard setup only has one rear fog - driver's side, (though it looks like you have two).
If it's not the fuse, bulb or holder, it's possibly the wiring around the tailgate hinge snapped, or the stalk.
Indeed it was the wiring the had snapped......Thanks matedogslife wrote:Check fuse - should be F19, passenger fusebox on your car, but they do vary.
Also it is fuse 19 on my box......but my fuse box is on the drivers side?!
Now my next project is.......Finding out what is causing the lack of boost till 3,000rpm? I have a feeling it is either the AFM or the Actuator/Solenoid?
406's have two fuseboxes, 'passenger' as in passenger compartment, to distinguish from 'engine' - engine compartment.Mastiff wrote:[it is fuse 19 on my box......but my fuse box is on the drivers side?!
