over heating 406 exec
I have a 1999 406 Executive 2.0 which keeps over heating. If I'm stood idling the red warning stop light comes on, its ok when I'm running around.I don't seem to be losing any water. Any ideas would be welcome
Re: over heating 406 exec
has the coolant been changed recently ?
what temp is it reaching ?
Do the fans work?
I don't know to be honest as I can't even see them but I do not hear the fan coming on
I don't know if coolant has been changed as I only got the car a few weeks ago. The temp gauge is showing just under 90 degrees when I'm running around but if I have to do a lot of stop start and using the clutch a lot the gauger goes right over and the red stop light comes on
my guess is,
thermostat fubard,
or faulty header tank cap
also check for an airlock,
thermostat fubard,
Thanks for info, how do I check for airlock
theres a bleed screw on the thermostat housing or there abouts,ronnyp wrote:Thanks for info, how do I check for airlock
and theres one on the heater pipes going into direction of bulkhead,
is your heater blowing out hot constant heat ?
also check the header tank asnt been overfilled,
if itsbeen overfilled it couid cause circulation problems
Fans should be working if it's that hot - (he's saying the temperature's just about OK unless it's stationary).
My hdi sits at 90 all day,
ive never seen or heard the fans cut in once,
what temps does other peoples cars get to before fans cut in ?
cheers
cheers
- Site Admin & Mad Biker!
The fans should be running at half speed around 90c, you can't really hear them with the engine running but they are on. If one of the fans fail the other will run at full speed all the time. At least on a D8 anyway.
Thanks for the help, looks like I'll have to wait till I can afford to put it in local garage as I'm disabled and have problems with my hands unless there is some-one local from here who could have a look.
Been having a look at car 2 things I don't know if relevent.
Top hose is hot temp gauge says about 90 degrees bottom hoses are cold also when I open header tank it is cold. Does all this mean anything
couid be air-lock that,
or Thermostat might be stuck closed
other possibilty if not the above 2 :
Water pump
Water pump
i would get the thermostat changed 1st mate .
whats your postcode. i live wigan lancashire. if i'm free one day this week could pop down and change the thermostat for you .
