antifreeze
john170277
antifreeze
Post by john170277 »
hi how much antifreeze do i need to put into a 110 hdi
cheers
Re: antifreeze
10.5 litres (but do not put this amount in if your using concentrated antifreeze)
i got this info from castrol and comma websites 8)
craigtd
Re: antifreeze
Post by craigtd »
put 4 ltrs in if the systerm has been drained compleatly then top up with water. :)
Re: antifreeze
i would recommend a 50/50 mix . thats what i've always done
but craigs way will also be fine as well 8)
craigtd
Re: antifreeze
Post by craigtd »
its best to use the long life stuff aswell unless you plan on changing it every year.
