getting a feed off side lights,
anyone got any ideas,
iwant to add these
http://cgi.ebay.co.uk/pair-MERC-led-sup ... 35b11f1ea6
idont want fog lights on my car but ithink these will look good,
but how can iget a feed off my side lights?
iwill be putting them the other way round not like on the pic on the merc box 8)
thanks inadvance
Re: getting a feed off side lights,
2nd question
how couid i get a supply for some lights inside the car,
im thinking of adding these down the curved part of the centre console so the lights shine into the footwells
http://cgi.ebay.co.uk/LED-DAYTIME-RUNNI ... 3a65258503
Regarding the DRL's you could just scothlock a tapping off the sidelight wiring, (note the left & right are off different fuses).
I thought about this too, but would you want them on with the sidelights? I'd be tempted to go for a separate switch /ignition controlled supply.
cheers mate.
iwant them running off side lights as iwouidn want any none standard looking switches inside the car idont fancy cutting out holes for switches ..& i dont want the car looking like its been a taxi if icome to sell it if you know what imean :roll:
lozz wrote:cheers mate.
i understand you lozz, fog lights might have a better range but if its these which you prefer then they should just be a case of feeding them off the sidelights.
as for the inside your best bet is to take a 12v feed from the battery through THE GROMMET OF MANY WIRES and on ahead in, then your free to work with the 12v supply.
cheers frank
yup iwill patch into the side lights,
as of adding more interior lights ithink iwill have ago at the tow bar wiring some of it runs through the inside of the car anyway so it might be worth a try ..
dont use them blue things, (Are they called scotchlocks) they rust and loose connection. An auto electrician friend of mine told me one time "focking shite dont put them near your car" but i seen some cheap and installed my parking sensors with them, great for a month then they did as he said, lost connection. I ripped them out and got a told you so from my friend.
Solder is the stuff, a bit of heat shrink round it and it makes it a neat job.
as for the interior lights, what do you want to do with them.
i like discussing lighting of the interior
What do iwant to do with them?
not alot realy just after some lighting in the footwells but im going to be using them Led strips and curve them round the sides of the console,
Maybe some other lights will be added in other places after that speaker covers and heater vents possibly if ican find some bulbs or leds that wont cause too much glare,
and do you want to switch them on with a switch or come on with something?
FarmerPug wrote:and do you want to switch them on with a switch or come on with something?
Re: the speaker lights,
im thinking of something like this
http://cgi.ebay.co.uk/Blue-LED-Car-Spea ... 5d2727090d
ive got to get my tape measure out tomoz and work out what to order,
im thinking of grabbing some covers like thems and fixing them over top of the standard covers,
in the front?
when you remove the speaker grille in the doors, the clips holding them in run along the outside, is that ok.
idont know tbh ,
iwill have a propper look
the covers pop off iknow as ihad them off the other week but iwas thinking of leaving them in place and just screwing the covers over the top of them ,
or if thats a fail iwill just implant some leds behind them somewhere they will be just as efective as door lights ishouid think
sussed it !
iwill just use the conection from the ashtray bulb -and the one for the ring thats sposed to light up round the cig lighter,
idont use either of em anyway so it carnt do any harm using them couid it ?
if iuse the Led strips and leds they shouid be- low votage users ishouid think,
hopefully it will save me hacking into the tow bar wiring .
I don't know if they are bsi or not but the cig lighter gives an ignition controlled safe power supply
FarmerPug wrote:I don't know if they are bsi or not but the cig lighter gives an ignition controlled safe power supply
cheers for the info,
iwill just try them and see what happens, 8)
