My fan/air con won't work and I believe I need to obtain a wiring diagram in order to trace the wires back.
Can anyone tell me how I can obtain one at a reasonble price?
$06 (2000) wiring diagram
Re: $06 (2000) wiring diagram
Welcome A board to this great community !
Can you be a little more specific about your car ? model, year, motor... maybe i can help you
hi & welcome in.
if you have a d9 facelift model it might be a fault on the ignition barrel or the resistor pack which is located behind the the front of the centre console area,
d9 models are the ones with the honeycomb front grille
Of courtse - sorry I should ahve thoguht of that. I've taken this info from the log book.RayneR wrote:Welcome A board to this great community !
Peugeot 406 LX
4 door saloon
1761cc
2-axle rigid body
Petrol
1st registered 23/03/2000
It's interesting you should mention the ignition. Last October the plastic housing for the ignition overheated and fused so the key would not turn. A locksmith replaced it in the first instance with one from a scrapyard as the dealer part would have taken over a week to arrive and I needed the car ASAP (plus the dealer part would have cost and arm and a leg!). However the same issue arose again in March and the dealer again replaced the plastic electronic switch - he said it was highly unusual to be this unlucky.lozz wrote:hi & welcome in.
He didn't think the two incidents were related. However, I'm still not convinced as when they fixed it the first time, the fan stopped working but slowly started working over the next few months. As soon as they fixed it the second time, the fan stopped working again. It's still not working. We also had a short spell of a few weeks in August September of the left indicator suddenly springing into action but whenever I took it to the garage, it would work perfectly.
I'll take a look at the grille tomorrow in daylight. Thanks for the info.
