is it possible?
reason i ask is cos i want to get some more out of my car and surely a decat is the best bet first. however - i have a lambda sensor before and after the cat.
can i do it then?
De-Cat for a 2.2 petrol
Current car - Ph3 1.8 306
Re: De-Cat for a 2.2 petrol
its possible ithink but the chances are it wouid fail on a mot,
why dont you just buy another cat and knock the insides out and keep your good one to put back on for mot time,
i know the ramifications of taking the car for mot without a cat.
i'm more concerned with how the current post cat sensor will read after the decat has happened. will it read the o2 level to a point of the cars ecu becoming confused and then throwing an error code up?
- Bailes1992
Get a sports cat?
Usually cheaper than a conventional cat, not at all restrictive and will pass an MOT
- sirwiggum
Bit of pipe.
if you have lpg you can bash the middle of the cat out and during the test it will still pass without a cat.
- sirwiggum
Never had an emissions test for MOT.
So long as it's not reeking smoke everywhere.
- highlander
- PowerFlow Shill
Every MOT I've ever had has involved emissions testing - I guess it's a petrol thing; diesels (apparently) don't get tested on emissions.
