Hello 406OC,
Could I ask for help in clarifying wiring for my installation for the new alarm purchased off of a well known auction site from a Peugeot dealer, the problem is the booklet supplied for wiring isnt all the informative. I have lost many a weekend installing Moss alarms in the olden days so i have some idea what i'm doing.
Booklet supplied and seperate peice of paper shows applications for either boxer/jumper, Renault, or 1 of 2 Peugeot/Citroen applications and makes reference of wwhat i presume is a central locking control box to using either a grey wire plugged into a multiplug A3 to unlock, or a purple wire plugged into A6 for locking. would my car have a central locking control box or does the BSI sort out the central locking?
also i'm okay with the following wires
red wire = 12volt+
pink wire =12volt+
orange wire = 12volt+ switched
yellow wires = indicator wires
white/green = wire trunk switch
2 way brown connector = LED
I'm not so sure of
white/black wire = connect to door switch, "Where there are no pin switches!!" would I connect this wire to the courtesy light?
The wiring diagram shows a set of 3 wire of the central locking (purple, purple/red, purple/black) and 3 wires for unlocking (grey, grey/red, grey/black) but no clear description of where specifcally all 6 wires are relevant to my 406.
Also it is possbible to clarify positions of LED, siren position and control box position including wiring through bulkhead etc.
Could someone help in terms of advice on only being able to switch on my alarm when the the deadlocking is activated via the 2 buttoned keyfob and wiring of the central/deadlocking.
Thank you in advance, Garry
Peugeot Alarm 9671.ZK, advice on wiring please
Re: Peugeot Alarm 9671.ZK, advice on wiring please
Hello Anyone there,
Can anyone help? Please!!!
