can anyone check the fuse number for the drivers side main beam please, going for MoT retest tomorrow and I've just spent the best part of an hour on the car park at work getting battered by the wind fitting a new bulb, refitting new bulb, swapping bulbs around, cleaning connectors, kicking tyre, swearing lots cos my foot hurt.
I'm assuming the near side and off side are on different fuses as the near side is fine??
O/S/F Main Beam Fuse 1997 TD
Re: O/S/F Main Beam Fuse 1997 TD
Main beam now sorted but I have another potentially stupid question.
Do both rear fogs light up on a D8?
I've tried bulbs and fuses, cleaned connectors and my n/s/r fog will not light up. I'm not very good with electrics but the diagram in my Haynes seems to suggest their is no power to the near side rear fog socket.
Is it a lhd rhd thing with different looms for different markets or is it just knackered?
MoT tester didn't pick up on it so I'm guessing the law says you only need one on the off side?
no
only the offside one works on a d8
thanks omega that's saved me some head scratching
