brakes
rallyman
brakes
Post by rallyman »
I have fixed my brake sensors and the abs light on the dash is off but the read out on the central screen on my executive still flashes up abs fault.does this need removing by an auto electrician.It also flashes brake fluid low even though it is full???
Re: brakes
Hi,
if the Mfd is throwing up a Low brake fluid Warning and fluid level is full,
it couid be a Faulty handbrake switch. mines been doing the same for a while now,
Does the Warning go away: when you release the Handbrake ?
rallyman
Re: brakes
Post by rallyman »
it comes on when I am driving so the handbrake is off.
