1.- How do I prevent the alarm from going off before I disconnect the battery
2.- Once the alarm is ringing HOW DO YOU KILL IT!? unlocking, immobiliser code and starting the car didn't stop it!
2 quick easy questions
- Hangar18
1996 406 Executive XU10J2CTE
1995 405 GLX XU7JP
1995 405 GLX XU7JP
- Site Admin & Mad Biker!
Re: 2 quick easy questions
1. I'd always found that as long as the car is unlocked you should be able to disconnect the battery without the alarm going off?Hangar18 wrote:1.- How do I prevent the alarm from going off before I disconnect the battery
2. You have to hold down the internal sensor disable button to switch it off
