Hi all, after spending all day preparing my car for a ecu map upgrade, it appears my Galletto 1260 EOBD2 OBDII CAN ECU Flasher Remap Tool is no good
3 hours ive spent with two different laptops on two different cars and it wont read the ecu's. I was wondering if theres anyone local with a cable i could use, i will pay you
the only reason i am in a rush is ive removed my DPF today and i'm a little worried about the ecu going into limp mode without the correct map installed
thanks for any help in advance
