RAPIER BRAKES
RAPIER BRAKES
just noticed the last couple of days when i press the brake pedal i can hear the pads making contact with the disc,like a metal tinny noise.the pads and discs all four corners were only fitted five months ago,any idea chaps.
Re: RAPIER BRAKES
have you actually checked the pad thickness, if you have a seized caliper then you will found out it will wear out the inner pad very quickly. it could possibly just be the back plate thats rubbing slightly. but the rear calipers are prone to seizing. time to check before they take out your discs
To rebuild the impossible is possible by making it become a passion..... Oct 2001 406 2.2HDi 16v Executive..... A work in progress
Re: RAPIER BRAKES
all pads and discs are fairly new (5 months old ) on all four corners
Re: RAPIER BRAKES
but the calipers arnt.parcelman wrote:all pads and discs are fairly new (5 months old ) on all four corners
