I am the happy owner of a 406 (1997) estate (family) with a quick question.
The switch in the door frame which turns the roof light on when the door is opend is defect and i cant seem to work out how to remove it for replacement.
Have removed the black rubber cap and now there is a yellow round piece of plastic.
Seems that this must be removed somehow so that the switch can be pulled through.
Any help?
John T
Cabin light.
Re: Cabin light.
you can lever them out if you carefull they must push in from the front as they have prongs that locate at the back
Re: Cabin light.
Thanks for the reply but i am a bit confused with your reply (wife thinks im allways confused!)
Do have to lever/prise the yellow disc off and then pull the switch through the hole, and if so, can i re-use the plastic disc or can they be bought alone (without the switch) as a spare part.
