I can't use it in project vtr, good condition, no whines or other noises. These boxes were also used in the 2.1td and the v6 good strong boxes these. Speedo sensor not included, but will throw in the complete hydraulic system (sealed master and slave cylinder)
50quid collected from dn34 grimsby.
2.0 turbo gearbox
- TRAVIS BICKLE
2.0 turbo gearbox
98, Executive turbo estate in aluminum silver. The stealth wagon! Now departed, New project Xsara VTR-8 in progress, Next Project, 406 D8 / JAP. So will be looking for a 406 again when the xsara is done!
- TRAVIS BICKLE
Re: 2.0 turbo gearbox
Bumpy
I just thought I'd point out
You sure you wanna part with it Trav?
As fitted to the afore mentioned cars, the whole thing is one complete, not-possible-to-take-apart piece and no longer supplied by Pug.TRAVIS BICKLE wrote: the complete hydraulic system (sealed master and slave cylinder)
- mjb
- Site Admin
You're advertising it wrong! It should be D8 clutch hydraulics £50 with free gearbox!
- TRAVIS BICKLE
These are true and valid points lol! These gearboxes don't tend to give much trouble so nobody ever needs one. I might be looking for another D8 at some point so might keep the rest of the bits I have left as spares.
- TRAVIS BICKLE
I was thinking this might sell better as an auto to manual conversion on the coupe forums?
As I have,
Gearbox
Clutch
clutch hydaulics
Flywheel.
Gear change cables
Flywheel
Pedal assembly.
Or, I might just keep it all and look for a D8 coupe V6 with a knackered auto box?
As I have,
Gearbox
Clutch
clutch hydaulics
Flywheel.
Gear change cables
Flywheel
Pedal assembly.
