poss problem how to diagnose?
jason j
Post by jason j »
Well after thinking the turbo seals had gone and a lack of oil causing the overheating for some reason I suddenly thought of the obvious!!! are the fans working.
What temp should the fans comeon at?? they are deffo not coming on by 90 degrees and pretty sure not by 100 either....... where is the fuse located for the fans and what else could cause them to fail?.
