406 GLX Gas conversion
aviator666
Post by aviator666 »
Hi all I have recently aquired a 1998 406 GLX auto saloon which has a Stako gas conversion fitted. The system was fitted (I beleive) in 2005 and was last inspected (with a certificate of conformity) in 2010 - looking at the underbonnet parts it seems to be pretty much 'plug and play' so should be suitable for most 2000cc cars. The changeover switch has a row of LED's which measure gas tank contents - simples :D
The tank is boot mounted (under the rear parcel shelf) and is 80ltr capacity the car has done around 100K and runs fine on gas or petrol, the tax (and the gas)! ran out last week so I'm going to break it, which seems a shame as it drives fine!
I am looking for £250 for the full gas conversion if you will come and remove, or £300 removed plus carrige if required. If you require any other bits please ask.
Vehicle is located between Peterborough and Kings Lynn, just off the A47. Please drop me a line if your interested.
Thanks, Paul.
