rear caliper bolts
rear caliper bolts
ok,rear brake calipers on my 406 r reg, should the slide up and down the allen bolt and bottom bolt for braking?
Re: rear caliper bolts
Yep.
thats what i though, loads of smoke on test drive but have new discs to wonder if its just running in,lol
Hi, is it that the caliper doesn't want to move along the guide bolt?
I had something like this on one of mine, this is how I unseized it:
1) I carefully applied some WD40 or similar to the sliding-bolt, made & drank a cuppa.
2) I put a large-socket over one end of the sliding-bolt, it was large enough to "cup" the end of the bolt and touch the caliper without touching the bolt.
3) I put a large G-Clamp on, so that one end of the clamp was pressing on the sliding-bolt, the other was using the large-socket as an extender to cup-around the other end of the sliding bolt and thus apply the pressure to the caliper (instead of the sliding bolt).
4) I was able to work the caliper along the bolt by a few mm until the bolt was effectively pushed to the limit of the clearance provided by the "cupping" large socket.
5) I reversed the side that the socket was cupping and worked the slid-bolt/caliper the otherway.
6) I repeated 4&5 several times, then cleaned & lubed everything up. Flew through the MOT on brakes.
NB: I did break one of my G-clamps when I failed to realise that I'd reached the limit of the clearance provided by the cupping-socket
Now if I can just fit the mods from "Taxi" http://tinyurl.com/3yug4g3
I can provide PP2000/Lexia 3 code reading/clearing in the East Cornwall/West Devon area.
