Finally got fed up of the brake fluid warning everytime I used the handbrake so went to the dealers and bought a replacement switch, the one with a mortar board cap on. Popped the centre console out fitted new switch and found under the console a coin holder with 2 one pound coins in. Switch cost less than 3 quid, found 2 so only one quid down.
After putting it all back together I thought, do I A) return money to previous owner after all he was the only other owner and only lives 30 mile away. B) spend it.C) Invest it on 2 scratch cards or D) 2 Euro lottery tickets on seperate roll over weeks thus giving the potential to make hundreds of millons and then be in profit on the job.
The coin holder now resides on my key fob whilst I decide.
Brake Fluid Low warning fixed.
- highlander
- PowerFlow Shill
Re: Brake Fluid Low warning fixed.
£2 will get you one Euromillions ticket, not two - I think they're £1.50 each, so at least you can get a bag of crisps at the shop as well when you buy it
