Reverse lights on 406 estate?
dukey406
Post by dukey406 »
Can anyone tell me where to find the switch that activates the reverse lights and or fuse?
I have checked both bulbs & holders and all seems ok, just no reverse lights :(
If it aint broke - dont fix it!.....
http://ddukey.deviantart.com/
406 HDI 110 GLX Estate.
Re: Reverse lights on 406 estate?
A quick search later
Mine's fuse 1 in the engine fuse panel, not sure what year your car is though. Try bridging the terminals + see if the lights come on.
D9406
2.2 16v
Post by D9406 »
Easiest way to check is as Steve says, pull off connector and insert small gauge insulated wire into both terminals then switch on ignition. If lights work then switch is at fault. I've just replaced one on a peugot, £6 including P+P for a new one from Ebay.
dukey406
Post by dukey406 »
Many thanks, tested it out with multimeter and it doesn't work, time for eBay!
omega
Post by omega »
or pop overto my house and you can take the one of my car for free!
D9406
2.2 16v
Post by D9406 »
If you tested the switch for continuity whilst the switch was still in situ you did have reverse selected didn't you? The switch is a plunger type and if not depressed will not make the circuit.
dukey406
Post by dukey406 »
D9406 wrote:If you tested the switch for continuity whilst the switch was still in situ you did have reverse selected didn't you? The switch is a plunger type and if not depressed will not make the circuit.
Yes, of course ;)
