406 exec serious boost problem! help!!!!
- 1.6 8v
hi guys, car was running fine and then all of a sudden lost all boost, now doesn't even feel like theres a turbo on there! no sound from the dump valve and boost gauge doesn't go past 0! any ideas on what this could be anyone please? thanks
- mjb
- Site Admin
Re: 406 exec serious boost problem! help!!!!
Sound from the dump valve?burnsey wrote:no sound from the dump valve and boost gauge doesn't go past 0!
Boost gauge?
It might help if you tell people what you've modified with the turbo when you're asking for help on it...
Sounds like your turbo's shafted. Not the easiest nor cheapest of repair jobs, that. There's been several recent posts about turbos you may like to search forany ideas on what this could be anyone please? thanks
- niz406
- Admin <BR>Turbo God
Typically I'd say.... siezed turbo...
You need to get the air feed pipe off and see if you can turn the compressor wheel with your fingers freely.... if it doesnt turn then its gone bye bye... its not that hard to repair replace, just time consuming... do you have any mechanical experience DIY or Commercial?
- niz406
- Davva2004
- Location: Stood beside my 406 with a sledgehammer, cursing everything French
- 1.6 8v
hi guys, thanks for the responses! just had it up on the ramps (again! have only just changed the gearbox!!) checked the actuator arm and can move that, havn't been able to get the pipe off to check the blades in the turbo yet but doing that 2morro! on the gauge, even if revved flat out, it only goes as far as 10hg so theres definatly no boost, can't even here the turbo spinning up! is it a common fault for the turbo to be working 1 moment and then just to seize up? have had quite a few turb'd cars before and not heard of it! gave no forewaarning that it was gonna go or anything! could it be anything else? have checked all the pipes etc. thanks again
- niz406
- niz406
- niz406
