headlamp fuse location
bigknickers
Post by bigknickers »
Hello learned ones, I have a 51 plate 110bhp 406 diesel estate, both headlights (dip beam) aren't working, I'd like to check the fuse, but have no idea where to find it, does anyone know where it is?
Re: headlamp fuse location
Hi,
full fuse list here, :arrowd:
BF00 - 30 Fuse Box (In passenger compartment
Fuses
Rating
Supply
Application
F1
10A
Acc +
Cig. lighter
F1 A
Batt +ve
Cig. lighter
F2
15A
Ign. +ve
Engine coolant level sensor, water in fuel sensor, instrument panel warning lamps, trip computer, vehicle speed interface module
F3
15A
ABS control unit
F4
10A
Sidelamps +
Front left side light, right tail light.
F5
15A
Low beam +
Head lamp height corrector, headlamp wash pump relay coil, low beam warning lamp.
F6
Free
F7
20A
Batt + ve
Caravan socket
F8
Shunt
F9
5A
Side lamps+
Front right side light, left tail light
F10
30A
Batt + ve
Control unit for memory seats and mirrors
F11
One touch window control unit
F12
10A
Ign. + ve
Oil breather re-heat resistor, reversing lamps, A/C engine coolant temperature unit
F13
20A
Batt +
Electrically controlled passenger's seat.
F14
Electrically controlled driver's seat
F15
Alarm control unit, radio telephone, fan relay, engine temp. control unit, control unit for memory seat and mirrors
F16
20A
Batt +
Radio
F16 A
Acc +
Radio
F17
Free
F18
10A
Low beam
Rear fog lights
F19
Side lamps
Illumination: Instrument panel, switches
F20
30A
Low beam+
Left low beam
F21
+ ign. off
Compressor cut-off relay, air conditioning compressor, pressostat, fan relay, heating/ventilation controls
F22
Acc +
Rear wiper and rear wiper timer.
F23
10A
Low beam
Right low beam
F24
30A
Acc +
Windscreen wiper, wiper timer, rear screen heater time switch relay, wiper control
F25
5A
Batt +ve
Radio memory, compact disc player, analogue clock, instrument panel, trip computer, coded anti-start, front and rear courtesy lights
F26
30A
Hazard warning
F27
One touch electric window
F28
15A
Acc +
Trip computer, load warning lamp, rear view mirror control, one touch electric window, ECU for memory seat and mirrors, high frequency receiver for central locking, front window lift and sun roof relay, stop lamps, digital clock
F29
30A
Batt +ve
Front window lift and sun roof relay
F30
15A
Acc +
Front and rear courtesy lamp, vanity mirror, glove box light, "lights on buzer" relay, overspeeding buzzer, radio telephone transmitter-receiver.
BF01 - Fuse Box (Under Bonnet)
Fuses
Rating
Supply
Application
F1
5A/7.5A
Batt + ve
Injection control unit (petrol and diesel)
F2
Free
F3
25A
Acc +
ABS and traction control
F4
20A
Batt + ve
Engine running
F5
7.5A
Relay XUD11ATE
F6
Batt + ve
Free
F7
15A
Head light wash timer
F8
Free
F9
10A
Acc +
Oxygen sensor
F10
Fuel pump
F11
Free
F12
10A
+ after relay
2665
Left front foglamp
F13
Right front foglamp
F14
+ ve after
switch 002
Left head light
F15
Right head light
BMF2 - MAXI (Fuse box under bonnet)
Fuses
Rating
Supply
Application
MF1
50
Batt +ve
Steering lock
MF2
Steering lock, + after ignition switched off
MF3
Supply 30 fuse box
MF4
Lighting and signalling switch, + relay horns
MF5
ABS/traction control
MF6
20
1-Fan Unit
MF6
40
MF7
20
1-Fan Unit
MF7
40A
MF8
Heated rear screen
Busman
Post by Busman »
At the risk of stating the blindingly obvious, are you sure it hasn't blown both bulbs? These spledid cars do have a habbit of eating the H7 bulbs. My new one has had two in 3 months.
Just a thought.
2003 HDI 110 Rapier Estate
1999 306 1.8 petrol.
bigknickers
Lozz, many thanks, Busman, I'm glad you said that, I've had 4 in a year! are there some bulb makes that are better quality and will last a few years?
bigknickers wrote:Lozz, many thanks, Busman, I'm glad you said that, I've had 4 in a year! are there some bulb makes that are better quality and will last a few years?
I'm trying a new approach this year - one of my dips failed in November, so I swapped all 4 headlamp bulbs for Aldi's finest at £3.99 / pair, to see if this avoids the usual bulb change every few weeks scenario. So far so good.
Just to complicate matters further, your 51-plate car is probably a later style fully-mux job, in which case your headlamp fuses are F9, 10, 11, 12 in the engine fusebox, (IIRC).....
ive got some Bosch bulbs if anyone needs any,
theyre sposed to be long life, idunno on that tho :|
