vehicle speed interface module and maxi fuse unit wanted
vehicle speed interface module (and harness or just connector with wires), maxi fuse unit and a double fuel relay wanted for 406 executive turbo. please help.
Re: vehicle speed interface module and maxi fuse unit wanted
can you post a pic?
which engine?
which engine?
i dont have a pic but the vehicle speed interface module is black box with a white bit on or near the connector located in the glove box around the other boxes. double relay is the brown or black relay next to the ecu on the loom. i dont know what the fuse nit looks like or where it is. not sure on engine. how would i find out? cheers
vehicle speed interface module is the black box with the white bit on or around the connector in the glove box. relay next to ecu on the harness. i do not have a pic sorry. not sure on engine how do i find out? cheers
well is it petrol or diesel
oh its petrol.
Your starter for 10 is...
Double relay is easy enough:
4549 35 RELAY 12V 20/30 AMP
Seems like most 406 have the same one.
Maxifuse though, what's that about? I guess the main fuses by the engine fuse panel, so do you need some fuses or the whole kit & caboodle?
The interface seems to be 1929SJ - I suspect these are ML5T only but I could be wrong and every D8 has one...bassline21 wrote:406 executive turbo
just need the v.s.i.m with its connector or harness and the relay. anyone got these parts?
dont they do hdi turbo exec or 2.1 turbo exec then steve?steve_earwig wrote:Your starter for 10 is...bassline21 wrote:406 executive turbo
They're diesel turbos - not having a pop, just thought it was a fairly reasonable assumption.
Sooo, who's breaking a D8 then? Gary!!
well i have a turbo exec[diesel] d8 and a 16valve petrol d8 that iam breaking but dont know if the parts are the same [not sure as well what iam looking for]
no i need parts for the 2.0 8v turbo engine. cheers anyway
They'll both have the relay, as I said I'm not sure about the interface but possibly (definitely if the dt is a 2.1)
ive found a local bbreakers with a fresh 406 turbo. ill pop there tomorrow and post if ive got the bits needed. cheers
