dose anyone else have this problem.... when im travelling around my air vents start whistling like banshees, it seems to be the one that deals with the windscreen.... but im not sure
any ideas??
many thanks peeps
dan
noisey air vents
i got the same issue before, turns out there is a small gap from the rubber side door panel seals (almost near the dashboard side). i took some hot melted glue to seal off the gap. it worked.
i don't think vent might sounded like whistling cause they got to be smaller holes to whistles. but i'm not really sure, try to look for side mirror opening or maybe one of your rubber door seals.
hope it helped.
hope it helped.
Cars, Computers, Chicks, 3C for a complete life. add a number 6 between them then you get double pleasure. hahaha!
ah that could be the prob... ive put my amp power cable comming throught the gap going through at the top of the bonet into where the doorr opens and closes, then under the seal then under the interior as i couldnt find a way into the car, and i didnt really fancey tring to drill any holes. ill ave to try and seal it up and ill let you know
