Anyone know what bulbs the MFD uses?
Mine have blown and I cant see what radio station I'm listning too
Bailes.
On my d9 there tiny little bulbs with a plastic base that push and twist in to the back of the mfd,similar to a dash bulb but smaller,if i were you do what i did and take one out and take it to a motor factors.
2012 "62" Yamaha XT1200
1974 "M" Honda CB500/4
1994 "M" Kawasaki Zephyr 1100
1998 "S" Honda XRV 750
Sorted,
Just for future reference...
Remove the two plastic blanks on either side of the MFD. These just prise out.
There is 4 T20 torx screws to remove and the MFD just slides out.
On the back there is 3 'twist & lock' bulb holders. If you remove the holders there is a small bulb to replace.
The bulbs you need are 286 Wedge Type bulbs. £1.99 each from hellfrauds
Fitting is the reverse of removal and...
Ta Da
Bailes.
I replaced some of mine last summer as they're the same bulb in the MFD and the digital heater control unit. Pretty sure I paid about 40p a bulb from my LMF.
gumby6371 wrote:I replaced some of mine last summer as they're the same bulb in the MFD and the digital heater control unit. Pretty sure I paid about 40p a bulb from my LMF.
Yep, mine were 3 for £1 from my lmf.
2003 HDI 110 Rapier Estate
1999 306 1.8 petrol.
I got 10 for 3£ on ebay, I also got some led ones but I've not tried them yet, may have to do soon since my headlights bulb on the dashboard seems to have left this world
They are a whiter colour than the OEM filament bulbs, so the red warning lights are a bit pinker, etc. But they have a service life that will far outlive the car.
They are a perfect fit in my D8, but obviously you need to work out which way round they go. With ones like main/full beams, just shove them in and try, and turn them 180 degrees if they don't work. These will fit the D8 clock (with a bit of fiddling), but not the D8 MFD.
Be aware that you can't use LEDs for some of them, notably battery warn, airbag warn, ABS warn, plus some others probably.
2002 D9 2.2 HDi Exec Estate - Samarkand Blue PM me for PP2000 diagnostics around Surrey
One thing I noticed when I did my MFD bulbs with LED's is because the LED bulbs are longer due to their design, then protrude into the MFD further and you can see them as spotlights on the display.
I used just normal white LED's so I'm thinking of roughing the clear plastic ends to see if I can diffuse the light better.
