New key cost?
Bailes1992
New key cost?
Post by Bailes1992 »
Anyone know how much I should expect to pay for a new key, cut and programmed from the dealer?
Bailes.
omega
Re: New key cost?
Post by omega »
dont need to go to a dealer for a spare key some key cutters have the gear to do it
Bailes1992
Re: New key cost?
Just ordered a refurb kit of ebay. My Unlock button was loose, started playing with it and now I lose it :roll:
Just hope the kefurb kit lets me swap the blade over. Some have the new blade moulded into the key.
I may try the local Peugeot Specialists then just to get a spare key sorted.
I suppose a D8 blank would do the job alright? Just as a spare.
Re: New key cost?
my uncle paid about £130 for a spare key and alarm fob for his 1998 volvo v70
Re: New key cost?
Sam dont pay daft money for keys mate,
next time your up north pop in Key fax
there based in dukinfield not that far from holmefirth if you get up that way,
thats where dealers get there keys made up they only charge £35 if that
Bailes1992
Re: New key cost?
Will have to try that place.
I'm more interested in getting a new key at the moment because the lock buttons fallen out of this one.
I've ordered a refurb kit, hopefully the blades swap over as I don't want to be trying to get one cut right now.
I've also bought a second hand 206 key in good condition that uses the same top half, so worse case scenario I just put all the 406 gubbins in the 206 key :)
£5 for both well spent :lol:
grasmere59
Re: New key cost?
Post by grasmere59 »
I was qouted from main dealer for my d9 £120 for a plip key and £65 for a non plip key,if you haven't got the immobiliser code they wanted anothe £20!
2012 "62" Yamaha XT1200
1974 "M" Honda CB500/4
1994 "M" Kawasaki Zephyr 1100
1998 "S" Honda XRV 750
moodybluetwo
Re: New key cost?
Post by moodybluetwo »
I have to replace my key….but it is covered under the cars insurance…I will post the total cost when the job is done.
Re: New key cost?
Bailes1992 wrote:Will have to try that place.
The actual microswitch on the PCB, or just the rubber from the cover?
If it's the latter, just get a similar key off ebay and swap the tops. If the PCB is knackered, then either learn your way with a soldering iron then try to repair it yourself, or get used to putting the key in the door and turning it :lol:
Bailes1992
Re: New key cost?
Just the rubber bit, and thats my plan ;)
jonsowman
Re: New key cost?
Post by jonsowman »
I got a 2nd hand good condition key off eBay and just replaced the top cover with the rubber bits, now I have a key that looks brand new without the hassle of having a new blade cut or having it reprogrammed :)
moodybluetwo
Re: New key cost?
The cost of a new key....with remote control....programmed....although I had the program number card I still had to pay £22 for the key number.......was £169.
grasmere59
Re: New key cost?
Buggeration! :shock:
Re: New key cost?
Bailes, you can buy the rubber insert from ebay think i pad £3 you just open the key remove the circuit board and pop the button in... or you could do what i did with my dads berlingo.. buy a cheap fob thats meant to just be a fob keep the half you need and aslong as it looks like your key it should work... Dont forget the little black magnet looking thing if you do it that way though cos your car wont start... the berlingo only cost £3.90 to do aswell.
gumby6371
Re: New key cost?
Post by gumby6371 »
Funnily enough I called in at the dealers earlier to enquire about a new button for my key fob. I was told they couldn't supply just the button I'd have to buy a new key for £131.50 plus VAT, he then said that was just the key, to code it to the car would be extra !!!!!!!!!!!!!!!!!!!!
I bandaged up my split sides and left still chuckling to myself, ebay here I come :shock:
