Board computer display problem
srdan
Post by srdan »
Hello there,
I have a big problem with board display.
I have around 30 vertical dark lines on my display. I could survive with that, but the main problem is than when I turn my heating on,
the display gets hot, and then the display goes totally dark.
Are there any known issues at circuit / chipset? Or there is issue at flat cable or just display?
If there is a problem with flat cable and display, does anyone know where could I get suitable on, which could fit on that circuit / chipset...
The new board costs 550€ ?!?! :S
BR
PEUGEOT 406 2.2 HDI
- DE-FAPPED
- EGR OFF
- IDLE SPEED OPTIMIZED (835 RPM)
- PRO TUNED
- LOOKING FOR 6 GEAR ML6C (CITROEN C5 2.2 HDI YEAR 2001-2003) TRANSMISSION ...
Re: Board computer display problem
try to find a 2nd hand used display and simply change them over.
over time the screen goes faulty and dies.
its just a case of buying one from a scrap car . very easy change over i think 4 torx screws and it will pull off ... unplug it then plug your new one in job done.
srdan
Post by srdan »
hello,
seams the reasonable solution.
Will try to find one.
Already find one, but has the same issue :(
Here at our place, there is not so much choice, maybe at your place better?
Do you have some website for second handed car parts? :)
thx
PEUGEOT 406 2.2 HDI
- DE-FAPPED
- EGR OFF
- PRO TUNED
plod
Post by plod »
I believe they do suffer from getting hot
I've even seen someone resorting to putting a duct in to cool the display
If it's the same as a coupe try contacting Ade1122 on ebay
1999 D8.5 HDi GLX - Sold :(
srdan
Post by srdan »
thank you. Found him and contacted as you suggested :)
thx
PEUGEOT 406 2.2 HDI
- DE-FAPPED
- EGR OFF
- PRO TUNED
