Electric mirror problem
cliffk
Post by cliffk »
Hi I am new to 406 ownership and now have my Autotrader 2003 406 2.0 110 hdi glx estate, there are a few niggles which I noticed on my test drive they didnt put me off the car but I need advice on how to fix them.
I am splitting them into 4 seperate posts as they may need idividual response
The electric mirrors wont adjust using the door mounted switch.
Re: Electric mirror problem
Re:mirrors,
can you hear the motors whirring when you try to adjust them?
if Yes, someones most probs siliconed the mirror glasses on/inplace,
seen this on my last 406 :(
gumby6371
Post by gumby6371 »
As Lozz says a previous bad repair could be the problem, worth stripping it down to see what lies beneath, removing the mirror is a pretty straight forward procedure.
The other option would be a dodgy switch which again is a fairly straightforward thing to remove.
Strip the mirror assembly first and if everything looks ok I'd be off to the breakers for a replacement switch.
cliffk
Post by cliffk »
Thanks guys will check it out when I can get on it in the daylight
It could be the LH/RH mirror selector switch that's mucky; especially as both mirrors aren't working. I had this problem on my D8.
cliffk
Post by cliffk »
Can it be cleaned? if so how? let me know and Ill have a go
you would need to replce the switch if its that, it wont clean no. its probably gone with water getting in it over time with the drivers window being open when raining..
buy a new switch 2nd hand just to rule it out if its not that its onto the next plan.
chance are its switch if both mirrors are not working
Are the Mirrors even getting power?
1 not working is common but 2 not working hmm, :?
cliffk
Post by cliffk »
not sure if the mirrors are getting power will have to wait until the weekend to check, there are a few electrical niggles see my other posts all could be power issues, Sat nav disk player not running, horn not working and mirrors not working, also the interior lights not working, main light above rear view mirror works but individual map lights dont I havent checked the bulbs yet though.
grasmere59
Post by grasmere59 »
cliffk wrote:not sure if the mirrors are getting power will have to wait until the weekend to check, there are a few electrical niggles see my other posts all could be power issues, Sat nav disk player not running, horn not working and mirrors not working, also the interior lights not working, main light above rear view mirror works but individual map lights dont I havent checked the bulbs yet though.
My map lights don't work unless the ignition is in the first position.
2012 "62" Yamaha XT1200
1974 "M" Honda CB500/4
1994 "M" Kawasaki Zephyr 1100
1998 "S" Honda XRV 750
cliffk
Post by cliffk »
Oh OK will check thanks
