Swarf in fuel system
helston90
Post by helston90 »
Help.
Just been told by my local Peugeot dealer that the bearing in my high pressure fuel pump has gone resulting in swarf in my injectors/ filter/ pump etc.
He told me he's seen it many times before in my 2002 Hdi engine and that an almost complete new kit (or a second hand/ recon engine and flush through the lines and tank) were needed.
This was a new one on me- just wondered what other peoples experiences of it were? and what fixes they did to get back on the road?
The car only has 87000 on the clock so don't want to scrap her, just very annoying! :cry:
2002 406 HDi 90 Rapier Estate
2001 206 1.6 GLX
Re: Swarf in fuel system
Hi there , if you have a 110bhp 406 the swarf is more than likely coming
from the in tank fuel pump and not the high pressure pump , common
failure on these cars , early signs are car doesn't start first time .
What has the garage based their diagnosis on ? if it is just the swarf how
much swarf was present ( this will be in the fuel filter housing ) and if i am
correct the fuel goes through this to the HP pump so the filter has done its job,
several people have had this prob , replaced in tank pump and fuel filter and
everything has been fine ...
grasmere59
Post by grasmere59 »
Why did the car go to the garage in the first place,what where the symptoms or was it just picked up on a service visit?
2012 "62" Yamaha XT1200
1974 "M" Honda CB500/4
1994 "M" Kawasaki Zephyr 1100
1998 "S" Honda XRV 750
Bailes1992
Post by Bailes1992 »
They probably saw swarf in the fuel filter. Totally normal. Chances are it's wearing but it will be fine for a long while!
What I will reccomend is pick up some fully mineral low ash two stroke oil (Castrol Actevo 2T from Halfrauds or Tesco) and put 250ml in with a each full tank of diesel. Will help lubricate everything and keep everything clean.
helston90
Post by helston90 »
Hi,
It's 90 bhp one, not the 110, it's never had a problem starting- even when left alone for 2 weeks over Xmas it still went on the first go!
It was in the garage because it came up with a antipollution fault on the way to work and a engine management warning light and went into limp mode. I had to take it to Peugeot to get a diagnosis on the fault in order to know where to start.
The fault only occurred when driving at higher rev range/speed but apart from the fault no other signs anything was wrong until it then.
Report came back
'Various fuel pressure faults present. On further investigation swarf found in fuel filter and pipework (due to high pressure pump breaking up) cleaned out as much as possible- complete fuel system may be req to rectify.'
He says he cleaned the filter out completely, ran the engine and it was covered in swarf again suggesting it was in the fuel, tank, pipes etc.
May give the two stroke oil a go to try to smooth things over a bit. A replacement fuel filter was sat in my boot waiting to be fitted so it wasn't looking pretty in there when it went into the garage.
2001 206 1.6 GLX
grasmere59
As said it sounds like the low pressure pump in the tank giving up,the filter should have stopped the swarf getting to the high pressure pump i would have thought as that is what it's there for.
Bailes1992
High pressure pump won't cause swarf in the fuel filter. The high pressure pump is after the fuel filter. If you had swarf in there the injectors would be shot.
helston90 wrote:Report came back
and dealers told you this :shock: :shock: :shock:
idiots have no idea :shock: :shock: :shock:
Bailes1992
It could technically run down the return back into the tank. But when it's in the tank it would just settle to the bottom.
Swarf in the filter is a sign the low pressure pump is on it's way out.
If there was swarf going down the return the injectors would be long gone.
Bailes1992 wrote:If you had swarf in there the injectors would be shot.
I think that's what the dealer is implying. Lift pump failure is quite common on those (listen for rumble or lack of coming from under the back seat) they often go around those miles too. Usually they just stop working as the brushes wear out (you can sometimes get them running again by giving the tank a thump) but they occasionally do fail more dramatically and fill the pipes up with swarf.
I suspect we had a high pressure pump failure once but I can't remember when it was.
I reckon you should at least get a second opinion, it's not impossible for the HP pump to fail but the dealer there makes it sound like an odds on certainty, which it just aint.
Edit: Do we know if this is Bosch or Siemens? If it's Siemens it aint got a lift pump...
Bailes1992
Siemens don't have a lift pump? My dealer quoted a price for one for me the other dar? :|
helston90
Post by helston90 »
The quote I put was copied from the invoice they gave me written by the mechanic,
they're basically describing this problem http://www.peugeotcentral.co.uk/ftopic-9101.html and the customer service bloke said he see's it more with the early 307s but it's not unknown in the 406's.
Now that I know the location of the fault I can at least now get my local garage to have a look themselves.
I still can't see why I can't replace which ever pump is going/ gone and flush the system through (but I'm not a mechanic!)
2001 206 1.6 GLX
Bailes1992
Have a look at your injectors for me and see if they say Bosch or Siemens. You may have an engine cover you will have to remove.
if it's semens it'll have a priming bulb in the fuel supply line to the filter, somewhere just in front of the bulkhead methinks
Bailes1992
Doggy wrote:if it's semens it'll have a priming bulb in the fuel supply line to the filter, somewhere just in front of the bulkhead methinks
Mines right behind the fuel filter housing!
