Coolant Gauge
gumby6371
Coolant Gauge
Post by gumby6371 »
Took my new 1.9td out yesterday for it's first proper run, 90 mile round trip on motorway and dual carriageway driving. I noticed that the coolant temp rose nicely from zero to 75 but went no higher.
Usually I would suspect the thermostat but I recently had an issue with the speedo jumping about between 40 and 65 mph due to dirty connections on the back so I'm wondering is the temp gauge itself at fault?
Has anybody else come across this? Gary if you're about did you have this on your 1.9's?
The clocks will be coming out soon for a couple of bulb replacements but I don't fancy risking overheating in the mean time. No dry joints were evident when I fixed the speedo error but cleaning up the 4 prongs sorted the erratic needle.
Should I just change the thermostat and clean the temp gauge connections anyway?
Re: Coolant Gauge
Its normal for this time of year ithink,
My Hdi wont sit at 90 even after running all day,
summer time it will no-doubt :roll:
gumby6371
Re: Coolant Gauge
Post by gumby6371 »
Thanks for the quick response Lozz, I was driving fairly steadily at the speed limit as the fuel gauge was saying 'you need to sell a kidney soon' so sat at 70 on the motorway but I would still have expected the temp to go above 80 on a 45 mile journey.
I must say when I did put my foot down to overtake considering it's a 90 BHP 16 year old diesel the pick up was fantastic so I know the engine is tip top.
Re: Coolant Gauge
Ialways try to get mine up to 90 on the Temp but its not Happening, :( (if itd sit at 90 it Might make it abit cheaper to run, ithought )
36mpg tops on arun, Roll on summer 8)
jonsowman
Re: Coolant Gauge
Post by jonsowman »
I've got a 80C thermostat in my 2.1TD so mine sits spot on 80 all the time. I think there's also some stats available with different temperature ratings.
Bailes1992
Re: Coolant Gauge
Post by Bailes1992 »
My HDi sits at 90 all day and all night.
Can get the oil upto silly tempretures and the coolant sits at 90 no problem.
Re: Coolant Gauge
Bailes1992 wrote:My HDi sits at 90 all day and all night.
How've ya got it running at 90 sam ?
Hmm, does that Lawnmower oil make it run hotter, if it does im firing some in, Feck the ozone :frown:
Mines been running all day, Most days never get anywhere near 90, Neither did the 406s ihad or the 407,
iput it down to the cold weather, :?
Bailes1992
Re: Coolant Gauge
No just happily sits at 90°c. Not many HDi's do, and lots of people say it's not supposed to. But my Uncle says it's done it since it was new.
I think thermostats get abit sticky and thats why they all run cool. The thermostat shouldnt open till 84°c anyway.
The two stroke does make the diesel burn hotter, but it's neglible.
grasmere59
Re: Coolant Gauge
Post by grasmere59 »
My old 2002 110 Rapier ran at 90 and my 2003 110 exec gets to 90 in about 4-5 miles and the oil temp runs at 90 but that takes a few more miles to get there.
2012 "62" Yamaha XT1200
1974 "M" Honda CB500/4
1994 "M" Kawasaki Zephyr 1100
1998 "S" Honda XRV 750
Bailes1992
Re: Coolant Gauge
My oil temp runs around 90 in town, the gauge is dead vertical on the motorway.
Re: Coolant Gauge
Thanks,chaps,
im going to change the thermostat me thinks,
Jonsowmans idea is agood one, on the two differnces of the thermostats, il have a chat with someone who sells me parts and see what comes up on his parts database,
Perhaps il change the oil too,
Re: Coolant Gauge
ive sorted the Temp on mine,
all it needed was a bit more coolant, :oops:
something iforgot to check,
