Wouldnt start other morning @ 5 deg, 3 tries and battery went flat. Called out RAC, jump started. tested battery all ok, tested charging all ok. RAC man put tester in circuit and found small drain on battery, turned out to be boot interior staying on- removed bulb and all ok.
Next morning same thing, finally started on 3rd and last turn.
Picked up and changed glow plugs next day - all ok for next few days.
Colder weather back and not starting again - did suspect relay controling glow plugs but think its working.
1.Turn key, ignition lights on, hear fuel pump, glow plug light on for 1 sec approx, glow plug light off, hear fuel pump wirrrr off, leave for another 20 sec and hear a click from engine bay.
Thing that is getting me is three tries at starting car flattens battery, its like something on starting circuit is draining battery while turning engine.
RAC insist battery is pushing ou 14+v and charging at 450ah (something like that).
Any ideas as getting annoying now.
How long is glow plug light meant to stay on for?
And why is it only below 7 deg that is wont start?
